Hi, I'm using the suito with PML. Is it still necessary to calibrate the trainer or is it sufficient to calibrate the Power meter?
Cheers?
Suito Calibration with PML
Re: Suito Calibration with PML
If you use the PML, power comes from your power sensor.
So, it's not necessary to calibrate the trainer
If I don't use PML?
If I connect my external/separate power meter (to zwift), will I still need to calibrate my Suito-t trainer?
No, it's not necessary
