Heart Rate Monitor: Change 'Bluetooth' to 'Ant+'
d_woodhouse
In MyETraining I have incorrectly set my HR monitor to Bluetooth when I should have set it to Ant+. In MyETraining I cannot change my from Bluetooth (which is incorrect) to Ant+ which is correct. How can I do it?
Re: Heart Rate Monitor: Change 'Bluetooth' to 'Ant+'
You can always repeat the configuration.
If you cannot select ant, it's because your device doesn't support it (I suppose).
Which device are you using?
d_woodhouse
Thank you for the reply.
I have a Garmin heart rate monitor which on the reverse side shows ANT+ which I take to be how it transmits my heart rate. In any case, the software did not recognise the HR monitor after I had incorrectly ticked the Bluetooth box.
I still cannot use the software as it will not recognise the HR monitor.
Not sure to have understood.
On which device are you running the software? It must support ant+ to connect your hr belt
feluco69.fs
Yo acabo de adquirir el Elite Direto XR-T y me pasa lo mismo. Después de configurarlo a través de Bluetooth no encuentro la forma de cambiarlo a Ant+.
Desinstalo y vuelvo a instalar el programa en el ordenador portátil y no me permite el cambio.
¿¿¿Solución posible???
Si el ant no es disponible, puede significar que:
- ant+ no esta soportado o no hay una llave ant usb conectada
- la llave ant no esta reconocida (por ejemplo, los driver no son instalados)
- la llave ant esta reconocida pero es ocupada da otra aplicacion (por ejemplo garmin express)
