Constant Beeping Elite Direto ????
Wildy
Postby Wildy » Tue Oct 31, 2017 10:24 pm
Can anyone help??
Got my new Elite Direto today and gave it a little try. Is it normal that it keeps constantly beeping??? I'm aware it make a sound on initial start up when the power is turned on but I don't think it's right that it keeps beeping during a ride???
Am I missing something?
Re: Constant Beeping Elite Direto ????
Postby Elite Admin S » Fri Nov 03, 2017 11:14 am
the sound you hear is the internal step motor that adjusts the resistance of the trainer. It does this adjustments during all the training.
In the normal usage of the trainer (so at normal speed), the sound should be merely noticeably as the noise of the chain is higher.
Erkeki83
Postby Erkeki83 » Sun Nov 19, 2017 3:24 pm
Hola yo tengo el mismo problema y el ruido es insoportable, se puede desactivar?? Gracias.
Erkeki83
Postby Erkeki83 » Sun Nov 19, 2017 3:41 pm
Es muy muy molesto, hay alguna manera de quitarlo?
Erkeki83
Postby Erkeki83 » Tue Nov 21, 2017 10:22 am
Is normal????????
Postby Elite Admin S » Thu Nov 23, 2017 12:54 pm
I confirm you that it is normal.
If you pedal at normal speed, the noise should be merely noticeable (the chain nois whould be higher).
If it is not so, please write to our customer care at real@elite-it.com adding a short video or record, so we can evaluate the sound level.
regards
Users browsing this forum: No registered users and 154 guests
