Suito RH bearing issue, belt contact
My Suito has developed a lean to the right and the belt makes contact and buzzes somewhere inside the main housing. I am assuming the RH bearing is failing. Can I order a bearing and the plastic spacers or can I get the spec on the bearing so I can replace it. Thanks
