Hi Admins
My serial number is Q2757 - is my unit firmware upgradable?
Brano
Qubo Digital Upgrade?
Re: Qubo Digital Upgrade?
Elite Admin S wrote:yes, it is upgradable
Hi, what about mine admins?
S/N: Q2757
Thank you!
Q5758 are upgradable?
Elite Admin S wrote:Contact the customer care for the procedure, a lot of users have done the upgrade successfully
I had my qubo upgraded (thanks) it works with zwift as power and cadence meter but I have no way to change the resistance. Do you have a solution, it doesn't connect with zwift as a controllable.
If you don't connect it as a controllable trainer, it's not possible to change resistance.
Are you sure that the upgrade has been successful?
Please reply to the email you got from the customer care service and explain the situation. They will ask you probably the log of the update and give you instructions
I have Qubo digital trainer, serial number is Q 1336, can i upgrade software to ANT +
second: how to calibrate Watt sensor
It's not upgradable, I'm sorry
Users browsing this forum: No registered users and 109 guests
