Qubo Digital Upgrade?
bran0
Contact:
Re: Qubo Digital Upgrade?
Postby bran0 » Mon Jan 28, 2019 12:50 am
Hi Admins
My serial number is Q2757 - is my unit firmware upgradable?
Brano
bran0
Contact:
Postby bran0 » Mon Jan 28, 2019 1:23 pm
Elite Admin S wrote:yes, it is upgradable
Hi, what about mine admins?
S/N: Q2757
Thank you!
jensy
Postby jensy » Sun Jun 30, 2019 8:54 pm
Elite Admin S wrote:@jonbrown7137,
I confirm you that it is upgradable.
Contact the customer care at real@elite-it. Dafont Showbox Adam4adam com and ask for the complete procedure.
Contact the customer care for the procedure, a lot of users have done the upgrade successfully ;)
mirkodeb
Postby mirkodeb » Thu Apr 02, 2020 2:52 pm
Q5758 are upgradable?
ideldoy
Postby ideldoy » Fri Jun 26, 2020 8:42 am
Elite Admin S wrote:Contact the customer care for the procedure, a lot of users have done the upgrade successfully ;)
I had my qubo upgraded (thanks) it works with zwift as power and cadence meter but I have no way to change the resistance. Do you have a solution, it doesn't connect with zwift as a controllable.
Postby Elite Admin S » Fri Jun 26, 2020 9:27 am
If you don't connect it as a controllable trainer, it's not possible to change resistance.
Are you sure that the upgrade has been successful?
Please reply to the email you got from the customer care service and explain the situation. They will ask you probably the log of the update and give you instructions
djole986
Postby djole986 » Wed Sep 09, 2020 6:43 pm
I have Qubo digital trainer, serial number is Q 1336, can i upgrade software to ANT +
second: how to calibrate Watt sensor
Postby Elite Admin S » Thu Sep 17, 2020 12:47 pm
It's not upgradable, I'm sorry
Users browsing this forum: Google [Bot] and 0 guests
