Firmware 078
craigwalker1993
Firmware 078
Postby craigwalker1993 » Fri Sep 03, 2021 9:10 am
Is there anywhere you can see firmware update notes ?
Just curious what changes are made ?
Re: Firmware 078
Postby Elite Admin S » Fri Sep 03, 2021 9:42 am
Hi Craig
Not in this moment, I'm sorry.
fab4mas
Re: Firmware 078
Postby fab4mas » Thu Sep 09, 2021 2:18 pm
Elite Admin S wrote:Hi Craig
Hi admin,
is something changed in connectivity (ant+ in my case) of the direto XR with this update ? Since i've update i ve disconnections with my garmin HR Strap and it only happens with indoor workouts...if i'm outside everything is fine.
thx
Re: Firmware 078
Postby Elite Admin S » Fri Sep 10, 2021 8:10 am
Hi fab4mas
The HR sensors are not connected to the trainer. They are connected directly with the phone/tablet/pc.
So, the problem cannot be on the trainer update.
Did you check the battery on your garmin strap?
enesto
Re: Firmware 078
Postby enesto » Mon Sep 27, 2021 7:34 pm
Hi, any update on this?
I would prefer to know the changes on this version before to install it, if it's possible.
Thanks for any help.
Ernesto
Re: Firmware 078
Postby Elite Admin S » Tue Sep 28, 2021 8:22 am
Hi Ernesto
I don't know which version of the firmware do you have in this moment.
The latest version of the firmware for Direto XR introduce the incline channel (used by the Rizer)
jean-benoit
Re: Firmware 078
Postby jean-benoit » Mon Oct 25, 2021 12:05 pm
I wanted to do the upgrade, however when I select my trainer on upgrado I have this message: "An error occurred while updating trainers info, some models could not be recognized".
Any idea ?
I have both trainer and internet connectivity from my phone (android 11) and it was working before.
I'm currently at 073.
Re: Firmware 078
Postby Elite Admin S » Tue Oct 26, 2021 12:13 pm
It seems a connection issue.
Power off both the trainer and the phone and restart them. If the problem is not solved, contact our customer care
prozorowicz
Re: Firmware 078
Postby prozorowicz » Sat Nov 27, 2021 5:22 pm
It's the same for me. I have this message: "An error occurred while updating trainers info, some models could not be recognized". Attempts to turn off the trainer / smartphone, reinstallation of the upgrado do not help. The same message - plus the inscription "Latest version update" in the middle. Elite Upgrado Android from November 25. Motorola Action, Android 11?
The upgrade actually works on a Samsung tablet. Also Android 11. I just updated the trainer.
Osso79
Re: Firmware 078
Postby Osso79 » Sun Nov 28, 2021 10:47 pm
the Uppgrafo app does not work with the Huawei p20 pro, with iOS yes.
Users browsing this forum: Bing [Bot] and 27 guests
