Is there anywhere you can see firmware update notes ?
Just curious what changes are made ?
Firmware 078
Re: Firmware 078
Hi Craig
Not in this moment, I'm sorry.
Re: Firmware 078
Elite Admin S wrote:Hi Craig
Hi admin,
is something changed in connectivity (ant+ in my case) of the direto XR with this update ? Since i've update i ve disconnections with my garmin HR Strap and it only happens with indoor workouts...if i'm outside everything is fine.
thx
Re: Firmware 078
Hi fab4mas
The HR sensors are not connected to the trainer. They are connected directly with the phone/tablet/pc.
So, the problem cannot be on the trainer update.
Did you check the battery on your garmin strap?
Re: Firmware 078
Hi, any update on this?
I would prefer to know the changes on this version before to install it, if it's possible.
Thanks for any help.
Ernesto
Ernesto
Re: Firmware 078
Hi Ernesto
I don't know which version of the firmware do you have in this moment.
The latest version of the firmware for Direto XR introduce the incline channel (used by the Rizer)
jean-benoit
Re: Firmware 078
I wanted to do the upgrade, however when I select my trainer on upgrado I have this message: "An error occurred while updating trainers info, some models could not be recognized".
Any idea ?
I have both trainer and internet connectivity from my phone (android 11) and it was working before.
I'm currently at 073.
Any idea ?
Re: Firmware 078
It seems a connection issue.
Power off both the trainer and the phone and restart them. If the problem is not solved, contact our customer care
prozorowicz
Re: Firmware 078
It's the same for me. I have this message: "An error occurred while updating trainers info, some models could not be recognized". Attempts to turn off the trainer / smartphone, reinstallation of the upgrado do not help. The same message - plus the inscription "Latest version update" in the middle. Elite Upgrado Android from November 25. Motorola Action, Android 11?
The upgrade actually works on a Samsung tablet. Also Android 11. I just updated the trainer.
Re: Firmware 078
the Uppgrafo app does not work with the Huawei p20 pro, with iOS yes.
Users browsing this forum: Baidu [Spider] and 32 guests
