Hello everyone,
I have been using Garmin Connect and a Garmin watch for all my sport activities for years.
Recently I purchased a Elite Suito, I was told this could be connected to Garmin Connect as well.
I have not been able to connect though. Does anyone know how to or have any tips?
Many thanks!
My best regards,
S
Elite Suito Garmin Connect
ymarti.ymarti
Re: Elite Suito Garmin Connect
If you select Bike Indoor activity you will see all devices connected properly in your watch.
Enjoy
PS: make attention to wheel circumference...
Enjoy
GOD SAVE THE RIDER
About circumference and speed, here's a useful link:
https://elitesrl.zendesk.com/hc/en-us/a ... party-apps
My 530 edge connected with no problems (via ANT+) to my Suito. J
My Garmin Forerunne 745 can see my Suito in 3 modes :
- Puissance,
- Vit/cad,
- Trainer.
May I connect to the 3 captors ?
Thank you.
- Puissance,
- Vit/cad,
- Trainer.
Thank you.
To have the resistance control, you have to pair it as trainer.
If you want only to see the data, without control (for example if you are controlling the resistance using another device or application), you can pair it as a speed&cadence sensor plus a power sensor
olialexlohnath
Elite Admin S wrote:Hi
I have the same question but for my watch fenix 5X and justo:
I see -vit/cad 175
-puissance justo
-puissance 175
what do i have to connect for just save the activity on garmin connect?
When you write "have the resistance controle" you mean that it's possible to create exercices from garmin connect for use on suito?
Thank You.
If I'm right, Fenix 5 doesn't support interactive trainers. This means that you cannot control the trainer resistance, you can only pair it as it was an external speed&cadence sensor plus a power sensor.
