hi,
I tryed to connect zwift via zwiftcompanion application. But kura trainer seen on zwift application as cadance sensor or speed sensor. power sourse dosent work.
And when i read the QR code for activade my trainer i have 'invaid QR code' message. I m not sure did i actived my trainer or not.
zwift kura connection problem.
- 02.jpg (104.13 KiB) Viewed 15324 times
Re: zwift kura connection problem.
Unpair the trainer as a speed&cadence sensor and select it ONLY as a power source.
This should solve the problem.
I borrow and try ant+ doggle. It works perfect. Thank you.
