Trying test and hr monitor
kona65
Postby kona65 » Tue Sep 18, 2018 10:12 pm
I went onto advanced configuration to add my hr monitor and the screen keeps flashing “wear your cardio belt” and does not add it why? My hr belt is from the garmin 735xt
Re: Turno
Postby Elite Admin S » Wed Sep 19, 2018 8:08 am
Hi kona65
Turno is not an interactive trainer or a simulator. It doesn't have a resistance control.
Simply, its resistance grows quickly with speed.
Here's a little document that explains how this kind of trainers work (it's about Turbo Muin, but the concept is the same):
kona65
Re: Turno
Postby kona65 » Wed Sep 19, 2018 12:14 pm
Hi, thanx for reply; what trainer would I need for the resistance to be altered by the app/program automatically
Re: Turno
Postby Elite Admin S » Wed Sep 19, 2018 12:57 pm
If you want a direct drive, you should give a look at Drivo and Direto.
Otherwise, you can consider Rampa or Qubo Digital Smart B+. Or the Arion Digital Smart B+, if you like the rollers.
Here's our webpage about interactive trainers:
http://www.elite-it.com/en/products/glo ... nteractive
kona65
Re: Trying test and hr monitor
Postby kona65 » Sun Sep 23, 2018 7:01 pm
What price for drivo and rampa
Postby Elite Admin S » Mon Sep 24, 2018 8:45 am
Here's the prices in Europe:
  • Drivo 1390€
  • Rampa 545€
Of course these are *suggested* prices, the shop may also apply some discount.
