Trying test and hr monitor
I went onto advanced configuration to add my hr monitor and the screen keeps flashing “wear your cardio belt” and does not add it why? My hr belt is from the garmin 735xt
Re: Turno
Hi kona65
Turno is not an interactive trainer or a simulator. It doesn't have a resistance control.
Simply, its resistance grows quickly with speed.
Here's a little document that explains how this kind of trainers work (it's about Turbo Muin, but the concept is the same):
Re: Turno
If you want a direct drive, you should give a look at Drivo and Direto.
Otherwise, you can consider Rampa or Qubo Digital Smart B+. Or the Arion Digital Smart B+, if you like the rollers.
Here's our webpage about interactive trainers:
http://www.elite-it.com/en/products/glo ... nteractive
Re: Trying test and hr monitor
What price for drivo and rampa
Here's the prices in Europe:
Of course these are *suggested* prices, the shop may also apply some discount.
- Drivo 1390€
- Rampa 545€
