Is the red light on the top of the control box supposed to be blinking or static when training...?
I'm pretty sure it used to be off when not in use and static when using the trainer...?
Now it is just blinking all the time...
Qubo Digital - red light
Re: Qubo Digital - red light
Hi Nemysys
well, the red led should be blinking when not working (no commands received) and static when working (commands received).
But it also depends which software are you using (our or third party).
The trainer works properly even when the led is blinking? Does it brake?
Which software/app/device are you using?
Admin S - many thanks for your reply...
The trainer 'seems' to be working properly - but the effort to control the watts output is much harder...!
Using Zwift as Training Tool....
Having unplugged and plugged in again - seems to have got the lights working again... but the effort is still 'hard'
There is a problem - or I'm losing fitness not gaining anything...!
Paul
Paul
Give it a run with my e-training app and tell me if you have the same issue.
Also, please tell me if you've ever changed the calibration point for some reason.
