No place for little magnet in my Arion Mag rollers?
I bought the Misuro B+ for my Arion Mag rollers, but I don't see a cover for a space to install the little magnet on the side of the roller.
Re: No place for little magnet in my Arion Mag rollers?
Not all the Arion Mag are misuro compatible.
You have to check if there's the magnet housing on the central drum (you should see the two screws that lock the housing)
If not, you need to buy the new central drum:
https://www.shopelite-it.com/en/spare-p ... mag-roller
i just got the arion mag rollers too and I see that i have the magnet covering, but it almost seems like there is no magnet there? Where exactly should the misuro b+ sensor be positioned as I cant seem to find this information anywhere.
thanks
nick
thanks
nick
