HI I bought an Turbo Muin Smart B+on January 2017. And some days ago it stopped connecting with Smartphone APP. It keep asking me to start riding, but I start and the connection is not set. Would you please help me? Is there a Battery inside the Trainer that I should change?
Thanks.
Turbo Muin Stopped connecting with APP
Re: Turbo Muin Stopped connecting with APP
Probably it's due to the battery.
On the lower part of the trainer, you should see a red plastic tap. Inside, there's a sensor (misuro B+).
Open it and change the battery.
On the user manual you can easily find the procedure to change battery.
renato.tumang
HI,
Drivo II needs to change battery too? Calibration failed but the trainer has 3 months only.
Thanks.
Thanks.
Drivo doesn't use batteries. It has a power supply.
Usually a failed calibration is due to disconnections (interference).
Please try again (also with a different device) and if the problem persists contact our customer care at myetraining@elite-it.com
What The Fuck? The word itself sounds bad in it and how a person will feel if you say that to him. The speedypaper reviews can teach you about good vocabulary and grammatical term. So, stop bothering the other guys with the improper forms.
