I'm going to borrow a hub meter for calibrating my trainer. So if my (hub meter) is reading 100 watts, and elite app is reading 80 watts, you would adjust your P value for (more) resistance correct?
Thanks, Bill
P1-3 values on qubo digital smart b+
Re: P1-3 values on qubo digital smart b+
There's a guided procedure in the app (advanced settings - calibration)
If the hub sensor is ant+ or bluetooth smart, you can pair it with the app directly.
If not, you'll have to read the values in three states and then insert them manually (it's all explained in the procedure)
