I need to conect the RealSofware with the Tacx flux, if can possible or it does not works?
Thank you.
RealSofwate to others trainers
Re: RealSofwate to others trainers
With Real software is not possible.
Theoretically, you could use my e-training Desktop pc software, selecting a direct drive (Direto or Drivo) and then changing the circumference value according to the trainer. But we never did any test with this configuration. You can give it a try
