Elite Qubo Digital Smart B+ (won't re-calibrate)
thomas.tyberghein
Re: Elite Qubo Digital Smart B+ (won't re-calibrate)
Postby thomas.tyberghein » Wed Jan 23, 2019 8:35 am
Dear Guisa,
Dear Elite,
I have the same problem with my rollers. What was the solution from Elite?
The don't answer me..
( resistance very high, low power readings, can't reset, break is always on)
I hope you can help.
kind regards
Thomas
(thomas.tyberghein@telenet.be)
kpijnaker
Postby kpijnaker » Wed Jan 23, 2019 10:34 pm
Hi there,
I seem to have the same problem. Has anyone found the solution?
Regards,
Koos
Postby Elite Admin S » Wed Feb 13, 2019 12:42 pm
This kind of issue requires a deeper analisys and some tests.
Please contact our customer care at myetraining@elite-it.com, the customer care will answer you within 48h
jorisvanderhenst
Postby jorisvanderhenst » Wed Mar 06, 2019 9:56 am
I had a similar problem. Guarantee period just expired. I informed elite end of 2018. A lot of mails from both sides and promises from their side (they would send a carrier to pick up the trainer and fix it but this carrier never showed up while i reserved time for it twice) and more than 2 months later i decided to give up. I'am buying a new trainer and it will be a tacx. Really disappointed in how Elite handled this.
jorisvanderhenst
Postby jorisvanderhenst » Wed Mar 06, 2019 9:57 am
