Could we please have some real information for this?
before I bought the trainer, I knew this was important.. but I read in this forum, a new firmware was comming out to solve this issue.
So I decided to go ahead and buy the trainner... Now I feel I got robbed, because I was promised something, and there has been like 1 year of delay on this subject.
I (we, for sure) would like to know if we are, indeed, getting support or if you just decided to promise something to get customers, and never respond.
Im sorry to tell, but what you're doing is so disrespectful with your customers....
Truth on Elite Drivo BLUETOOTH AND ANT+ simultaneously
Re: Truth on Elite Drivo BLUETOOTH AND ANT+ simultaneously
Hi sebrios
Man... you have touched a nerve.
We thought the Upgrado app (that allows users to upgrade their firmware) would have been ready in the beginning on this year.
But you already know this part.
We had some problem with it, as it didn't work properly with all the type of trainers.
As you can easily understand, a wrong firmware writing may cause a lot of trouble (if something goes wrong, you could end up with an empty firmware, that means that you cannot "try it again"). So, we had to improve the app and especially extend the beta test.
What I can tell now is that the app is ready and we're finishing the tests.
We will release it in late autumn.
We do understand your frustration and we're really sorry for the delay.
marcoromag
this is really interesting... I spoke with the support and they said there is no firmware planned. So what is the truth?
I've been talking to them directly, I can confirm they do are working on it.
I was so annoying that they even showed me the work in progress
Problem is, that when you use the app for the pedal analysis, and use other software (via ant+) with ERG mode, the trainner becomes crazy, and can damage it.
They have the firmware ready for dual connection... but its basically asking for trouble.
They said by October they have all those issues solved!
I have drivo II. I think if wahoo would let other trainers apps control the climb you could use it on drivo. My front wheel can go up down freely without interference from the rear side. And I have no problems with responsivnes. Works like a charm.
Users browsing this forum: No registered users and 167 guests
