Qubo Digital
pierrick.dumarterey
Qubo Digital
Postby pierrick.dumarterey » Tue Jun 05, 2018 5:30 pm
I have a connection problem on my qubo digital.
when I plug it in, the led lights up in solid red and it is impossible to connect to the HT.
Is there a procedure to reset or start a new detection.
Re: Qubo Digital
Postby Elite Admin S » Wed Jun 06, 2018 8:19 am
If it's the old version, it's ok that the led turns on when you power on the trainer.
About the heart rate, are you sure that your belt is ant+?
Did you do the pairing in the menu?
