create a course with MyETraining
raphnou
Postby raphnou » Fri Apr 27, 2018 4:18 pm
Hello Elite,
I try to create a course and in the 2 applications of MyETraining, it is the version Desktop or Android I can not create a course
With the android version, I click on "+", then "create a map", I name it and give the point of arrival and departure, I click "ok" then I have the message "impossible to create the map"
With the Desktop version, how to say it's a real Chinese puzzle to try to make a course, I can not add additional points, point B does not necessarily go where I want to go, a true bag of knots ...
I tried from Garmin connect, very easy to use for the creation of the course, but I do not get any topography of the course once imported in kml in MyETraining (I think it must come from garmin)
You tried to create a course with MyETraining? Does it work on Elite computers?
If so, could you explain how it works
Thank you
Re: create a course with MyETraining
Postby Elite Admin S » Wed May 02, 2018 9:38 am
In Android version, you shouldn't have issues.
Is it possible that you've inserted a non univoque point of arrival or departure? If it is so, the app won't be able to create the course.
Be sure to insert the complete name of the location.
About the Desktop version, to add waypoints you have to hold and drag a point in the track.
