Regulation of Intensity Level
elparon
Postby elparon » Mon Feb 26, 2018 2:44 pm
I found an issue with the "Regulation of Intensity Level":
- Target PWR is not responding to the increasing or decreasing on the intensity level.
Not in the target pwr windows either in the red block profile!
Anyway a Step of +/- 10% for intervals POWER trainig is too big!
it would be definitively better 1% !
Thanks in advance for your help
Best Regards
Pasquale Verderami
wolfgang-henke
Re: Regulation of Intensity Level
Postby wolfgang-henke » Wed Feb 01, 2023 3:06 pm
I also would very much appreciate being able to adjust the intensity levels in 1% steps. Has anything happened regarding this type of feature yet? it has been proposed 4 years ago.
cheers
Wolfgang
Postby Elite Admin S » Fri Feb 03, 2023 4:17 pm
Hi Wolfgang
Only few users have asked about this option in several years.
Also, if we use a 1% scale it will be very annoying for people that want to increase more the level.
The actual solution is a compromise.
Users browsing this forum: Google [Bot] and 6 guests
