Calbration with my direto on Zwift
girard_denis
Postby girard_denis » Wed Feb 21, 2018 11:20 am
Hi everybody
I need your help
I have just buying my ht
I have some problem with calibration and zwift how can I do that properly please ?
I 'm not sure of my settings .
DO I use the Elite FE-C 13400 for each items : power, cadencer, control ?
thx a lot
Re: Calbration with my direto on Zwift
Postby Elite Admin S » Thu Feb 22, 2018 12:23 pm
Calibration must be done from my e-training app (Parameter - Advanced settings - calibration).
About Zwift, you have to connect the trainer as a controllable trainer and select the option with the "fe-c" word on it.
girard_denis
Postby girard_denis » Thu Feb 22, 2018 9:23 pm
ok fine
I did the ftp long test (at last) and i felt resistance during it .. I set FE-C for all the stuffs
I don't know yet if all will be ok now
And i'm disappointed because my free trial period ended before I could test really other circuit.
Thx for your reply
