Elite Direto 12x142mm
rui_alex
Postby rui_alex » Tue Feb 20, 2018 1:58 pm
I have the Elite Direto trainer, but i lost the thru axle acessory that works fine with my bike (Cervélo R5 Disc Etap).
Where i can find and buy a new acessory? I found the 12x148mm adaptor in on-line stores, but is not the same that come in Elite Direto, correct?
Thanks.
Regards,
Rui Alexandrino
Re: Elite Direto 12x142mm
Postby Elite Admin S » Thu Feb 22, 2018 12:04 pm
Please contact the customer care at real@elite-it.com adding a reference of the part (look at the user manual)
alibi
Postby alibi » Sat Nov 24, 2018 6:42 pm
btw, if i have mtb with 12x142 qr thru-axle do i need some adapter with direto, or it already have all that need in box?
leonhayes
Postby leonhayes » Wed Aug 14, 2019 8:27 am
In your case, probably the power fluid is sufficient (indeed, you'll also need a sensor to make it smart).
happy wheels
