I own a Elite E-motion Rollers and what to use myETraining via Iphone.
My current Ant dongle only seems to work with a Windows pc.
Will buying a Ant+ dongle work?
Thank you
Re: Elite E-motion Rollers
E-motion is not an interactive trainer. Maybe you have the Real E-motion instead?
Is it the ant or the B+ version?
Which ant dongle do you have exactly?
Yes I own a Real E-Motion machine.
It is the ANT version.
I have the dongle supplied when purchasing a couple of years ago, an ANT dongle.
Can I purchase anything to get this machine to work with ipad/iphone?
Thank you
Thank you
There is a ant+ dongle, made by Wahoo, specific for apple devicese.
It's this one:
http://www.elite-it.com/en/products/glo ... dongle-ant
You'd also need the lightning/30pin adapter:
https://www.apple.com/uk/shop/product/M ... in-adapter
BUT ATTENTION!
Recently many users had problems with this dongle and the latest version of iOs. Someone is able to use it and someone no.
We are in contact with Wahoo, but in this moment they don't have a solution.
So, we don't suggest to buy it in this moment (only if you have an old model, with a non upgradable iOS)
It's this one:
BUT ATTENTION!
