Connection denied (Turbomuin Smart B+ & android phone)
lukasz.szewczuk
Postby lukasz.szewczuk » Mon Feb 05, 2018 2:26 pm
Dear Ragazzi
I get to see simillar question poping up here and there. I think it could be added to some FAQ.
Last week my phone stopped receiving signal from the trainer. I have tried to use the other phone, and nothing happend.
I thought, the problem might be the battery in Misuro B+ sensor. Eventually, I have done some 1000km. Changed the battery, configured Misuro with 12 blinks (S/N over 30000). Still nothing. Either by trying with My Etraining, or directly pairing bluetooth devices.
What can be done? I miss digits while riding :)
Best regards.
Re: Connection denied (Turbomuin Smart B+ & android phone)
Postby Elite Admin S » Fri Feb 16, 2018 10:59 am
I see you're already in contact with the customer care to solve the issue (it seems a configuration issue).
The technician that is following your case is waiting your reply
renato.tumang
Postby renato.tumang » Sat Aug 11, 2018 4:50 pm
I had the same problem and they said the annual subscription expired. Is gag correct?
