Original Real Turbo Muin Bluetooth upgrade?
FISHER1985
Postby FISHER1985 » Wed Mar 29, 2017 11:03 am
I have the original Real Turbo Muin with the ant+ connectivity.
I was just wondering if something was released which enabled this to be compatible with bluetooth devices?
Cheers
Danny
Re: Original Real Turbo Muin Bluetooth upgrade?
Postby Elite Admin S » Wed Mar 29, 2017 11:19 am
Hi Danny
I confirm you that indeed we have a firmware update for the Real Turbo Muin ant, but it only enables the ant + fe-c protocol (so, you'll be able to use it with non-Elite apps and devices compatible with fe-c trainers, like Zwift software or the Garmin 1000 device. The bluetooth cannot be enabled, as your trainer electronic board doesn't have the bluetooth smart chip on board.
If you want to upgrade your trainer, here's the link with the complete procedure:
http://com.elite.realaxiom.static.s3.am ... ng_5_2.pdf
FISHER1985
Postby FISHER1985 » Wed Mar 29, 2017 11:35 am
thank you for information & the quick reply.
alan.weinberg
Postby alan.weinberg » Fri Jul 21, 2017 2:40 pm
if the Real Turbo Muin B+ trainer is sent back to Elite could the board be replaced at factory?
Thanks.
Alan
Postby Elite Admin S » Mon Jul 24, 2017 8:15 am
If you have a Real Turbo Muin B+, you already have the latest version of the board. May I ask you why do you think you need to replace it?
Return to “Real trainers”
