Compatibility of the Arion digital console
negroool
Postby negroool » Tue Jan 30, 2018 7:59 pm
Hi there,
Does anyone know if the computer to control the arion digital is specific for each trainer? I mean ...If mine does not work anymore and I get a second hand one (of course also from an arion digital), will it work? I was just thinking that maybe the console can only control one trainer to avoid problems if 2 or more rollers are working side by side at the same moment... :roll:
I wrote to the customer service but did not get a reply yet. And maybe some of you have already had the same problem
Thank in advance guys !!
Re: Compatibility of the Arion digital console
Postby Elite Admin S » Fri Feb 02, 2018 12:09 pm
I see that our customer care has already answered you.
I confirm you that you can use it but you'll have to do the pairing from the settings menu (as indicated in the user manual)
Return to “Arion Digital”
