Which circumference value do I have to use?
Postby Elite Admin S » Wed Mar 29, 2017 10:23 am
Hi guys!
Let's talk about Circumference value! ;)
Sometimes it may be a little confusing, as different trainers need different settings.
Here you can find a table that will help you to check which circumference value you have to use in non-Elite apps & devices and in my e-training:
http://drive.google.com/uc?id=17rxczaZE ... ogPySELXTA
Also, here's a link where you can find a good way to measure your wheel circumference (if required):
ENG: https://elitesrl.zendesk.com/hc/en-us/a ... cumference
ITA: https://elitesrl.zendesk.com/hc/it/arti ... enza-ruota
That's all!
MM70
Re: Which circumference value do I have to use?
Postby MM70 » Thu Sep 07, 2017 9:23 pm
Per il turbo muin smart b+ la circonferenza di default proposta nella configurazione dell'app è 2070
È quella corretta?
Postby Elite Admin S » Fri Sep 08, 2017 10:22 am
La misura giusta da inserire è... quella della propria ruota ;)
Il valore di default è una misura standard generica, ma la cosa migliore è di armarsi di metro e misurare.
Ecco un procedimento semplice da seguire per avere una buona misura:
cliveweir
Postby cliveweir » Thu Apr 26, 2018 5:46 pm
Hi folks, I came here looking for the wheel circumference to use for my Direto trainer but it's not listed in the attachment:
Can you update please?
Postby Elite Admin S » Fri Apr 27, 2018 8:29 am
I'll do it soon, sorry.
About Direto:
- if you use my e-training app or software, you have to set the real circumference value of your wheel (for example, 2100mm)
- if you use a non-elite app or device (like Garmin), you have to divide the circumference value by 12.1 (for example, 2100/12.1= 173mm)
catchjigga
Postby catchjigga » Mon Nov 12, 2018 1:09 pm
cliveweir wrote:Hi folks, I came here looking for the wheel circumference to use for my Direto trainer but it's not listed in the attachment:
Thanks for the link.
cmk
Postby cmk » Sat Dec 29, 2018 12:38 am
Elite Admin S wrote:I'll do it soon, sorry.
About Direto:
Can you provide some insight for me. Do you know where I can change the wheel circumference for my Wahoo head units (Elemnt and Bolt)? Thanks.
shushil1kumar2
Postby shushil1kumar2 » Mon Jul 01, 2019 12:00 pm
Wow, this is what I was searching. I started searching fot this when I was providing Logo Design Services in Australia.
moltoviaxx
Postby moltoviaxx » Thu Jul 04, 2019 4:15 pm
Hi guys!
Bluestacks Kodi Lucky Patcher
l.marchioro
Postby l.marchioro » Fri Aug 09, 2019 3:14 pm
Guys, I'm confused.
The manual says, circunference / 13,2 = 2066/13,2 = 157. I've set this wheel size in my 920xt vel/cad sensor but I'm still getting wrong data input. 150/200km/h and 1400w. I've seen an youtube tutorial recomending to set the wheel size to 47 but my watch doesnt allow to set 2 digits values.
I'm lost here, would aprecciate some help.
