Unable to install right leg of Elite Direto
fdelrosario
Postby fdelrosario » Sun Jan 14, 2018 12:54 am
I just received my new Elite Direto S/N DIL170077. I tried to assemble it, but I couldn’t put the TCEI M8 x 70 Q Screw that attaches the right leg to the main unit. It looks like the main unit doesn’t have a hole drilled to allow the right leg’s Q screw to go in. Can you help me fix this?
Elite Direto.jpeg (197.34 KiB) Viewed 7650 times
Re: Unable to install right leg of Elite Direto
Postby Elite Admin S » Fri Jan 26, 2018 12:26 pm
It seems that the nut is not well in its location (maybe it is a little inclined).
Try entering in the hole with a thin screwdriver and move it.
If you're not able to put it in correct position, please contact the customer care at real@elite-it.com
thomaswiigh
Postby thomaswiigh » Sun Jan 28, 2018 10:16 pm
Remove the leg, and try to use the bolt.
My Direto did the same, but i removed the leg and did a test on the hole and it worked.
Sometime the top of the hole is hard to engage with the leg in position.
