I have same problem with tablet acer : no Bluetooth, no ant+ since last your update
and Try uninstalling the app and installing it again. If the problem is not solved.
It's not battery problèm
myETraining Not Working
Re: myETraining Not Working
Garry reinstall the app, it will work
Andrew
Andrew
Thanks for sharing
This is one of the most common problem user faces. I was having the same issue, so in order to resolve it, just follow the mentioned steps (it worked for me)
1. Un-install the app
2. Delete the cache and other files of the apps (do it via file manager)
3. Restart your phone
4. Re install the app
and the issue will be fixed. Do let me know if you are having problem performing the steps which I have mentioned above or if the problem is still there. Would love to help!
Regards, 9Apps Cartoon HD Shareit
I am also facing exactly the same issue and looking for a proper solution. Please help me.
kenna17 wrote:garryjoshi wrote:I own a Note 8 which earlier was running Android 7.0. Today I updated to Android 8.0 and now app is only displaying white blank screen when opened and closing itself automatically
I'm also same Problem My ETraining Not Working On Android Orea whenever I am opening the app it is simply crashing upon the startup.
I own a Note 8 which earlier was running Android 7.0. Today I updated to Android 8.0 and now app is only displaying white blank screen when opened and closing itself automatically after few seconds. Can anyone please help me fix it asap?
andiyatsia wrote:kenna17 wrote:garryjoshi wrote:I own a Note 8 which earlier was running Android 7.0. Today I updated to Android 8.0 and now app is only displaying white blank screen when opened and closing itself automatically
Did you solve this problem? I have the same and need help...
I have tried to use my one year free subscription to elite training received when I purchased my zumo but the elite website fails to recognize the serial number. What can I do,
Regards,
Aidan.
Regards,
Aidan.
Users browsing this forum: Google [Bot] and 17 guests
