I just purchased the Elite Direto. My bike is a Specialized Diverge 2015 with a thru axle with 135mm of length. It does not fit on the Direto. Is there a adapter available to make my bike compatible to the Smart Trainer?
Thank you.
Elite Direto with 135mm thru axle - Adapter?
martinbecker.de
Re: Elite Direto with 135mm thru axle - Adapter?
Can you tell me also the diameter of the axle?
Does it have the standard hub or the special Specialized hub?
Users browsing this forum: No registered users and 37 guests
