Factory reset a Direto?
mattalfie
Postby mattalfie » Sat Dec 30, 2017 9:26 pm
Anyone know if there's a way to reset the Direto?
I bought a Direto last week and have been trying to set it up for the past 2 days.
- For the first few minutes it worked well and synced with the MyTrainign app
- I admit that I didn't ride it for the 20 minutes but jumped quickly to Zwift to see if it worked there
- It paired immediately but also immediately shifted into maximum resistance - i can't turn the pedals at all.
- It has stuck there at max resistance - I have done everything advised elsewhere in the forum (switched off for few minutes, even overnight... restarted my phone and reloaded the relevant apps... tried on both windows with ant+ dongle and iPhone with Bluetooth...tried multiple apps including MyTraining, TrainerRoad and Zwift... nothing has worked
- I'm now also having trouble pairing the device at all
Appreciate any advice anyone may have.
Re: Factory reset a Direto?
Postby Elite Admin S » Thu Jan 25, 2018 12:00 pm
I've seen that you've also contacted our customer care.
We've sent you an email, but got no answers. Can you check?
salah.rahimi
Postby salah.rahimi » Wed Apr 01, 2020 12:18 am
Hi there,
I have recently purchased a Direto x. It seemed fine in the first day, then has exactly the same issue described here by mattalfie. I’ve tried the same, switching off the trainer over night and deleting/re-installing the My E-Training app and so on.
It seems that the app doesn’t configure properly when the Direto x drive is chosen as the app doesn’t read the speed correctly. I mean the maximum speed it shows is 3 km/h at very high cadence and power.
Can I ask how did you solve the issue, please?
Many thanks
Salah
Postby Elite Admin S » Fri Apr 24, 2020 6:02 pm
@Salah,
please contact our customer care to solve this issue
kubatmartin999
Postby kubatmartin999 » Sun Nov 12, 2023 6:47 pm
Good day. my directo xr has had a problem with the settings since the first launch, it is still giving it the highest resistance. could you please advise me how and if it can be fixed. well thank you
Postby Elite Admin S » Mon Nov 13, 2023 7:56 am
Hi kubatmartin999
It may be a problem on the internal motor or on the electronic circuit board.
Please contact the support at this link:
Return to “Drivo & Drivo II”
Users browsing this forum: Bing [Bot] and 53 guests
