This is the message I get when trying to pair my Misuro with my Pixel 2 phone.
I'm brand new to ALL this as I just got a Qubo Power Smart B+ for Christmas, so I don't even know what I don't know.
Immediately after I see this message, it sends me to the Playstore and to the ANT USB service app. Does this mean I'll need to get a USB stick and adapter for this to work on my phone?? I really want to use ANT+ so I can eventually get on Zwift.
Thanks for any help that can get me going as it's suddenly remembered it's December here in the heartland of America.
"ANT dependencies missing!"
Re: "ANT dependencies missing!"
If it is a Qubo Power Mag Smart B+, it transmits both in ant+ and bluetooth smart.
So, if your Pixel support the bluetooth smart, you should be able to connect it via bluetooth.
If you still want to connect via ant+, instead, you have to check if your phone supports the OTG connection and then use a usb ant+ dongle.
