Elite real axiom overheat
ddbernal@utas.edu.au
Postby ddbernal@utas.edu.au » Sun Dec 24, 2017 8:49 pm
I bought a wired elite real axiom secondhand and am finding that after about ten minutes of good power at about 3-400 Watts the whole unit gets super hot including the roller and it appears to even be damaging the trainer tire. The unit gives off a smell like melted plastic. If I stop the course I’m doing and spin for a couple of minutes it cools enough so I can do about another minute of good power but this seems a silly way to train. Any ideas about how to fix this? Is there a firmware upgrade that can prevent this or is the fan in the unit broken or something? Any suggestions appreciated
Re: Elite real axiom overheat
Postby Elite Admin S » Thu Jan 25, 2018 10:56 am
Is it the old coils version of RealAxiom?
If it is so, it may be that the internal coils are breaking.
Can you post a photo of the trainer?
Return to “Real trainers”
