I have a smart trainer it is the Qubo digital but it isn't the B+ model it just Qubo digital and I want to link it to the MY E-TRAINER app but it doesn't connect, my mobile-phone is a Samsung J2 PRIME, also the online web said that it is compatible.
I have others question
can i connect the trainer with a garmin 520? i tried but the garmin didn't find the trainer
which trainer can link up with my garmin 520?
compatibility with garmin 520
Re: compatibility with garmin 520
Qubo Digital transmits only using ant protocol, so your device must support this communication.
If your device doesn't support the ant+, you'll have to use a usb ant+ dongle and an OTG cable.
With the Garmin 520, you cannot connect to the trainer (it uses a special proprietary protocol). If your trainer is the upgradable version, you can upgrade it to make it ant+ fe-c compatible (and use it with the Garmin). But it must have a serial number higher than 9784.
If you want to do the upgrade, write to the customer care at real@elite-it.com and ask for the complete instructions.
