My E-Training don't see ANT+ power sensor from Direto
tom-wax
Postby tom-wax » Mon Dec 04, 2017 8:46 am
Ive just purchased a brand new direto trainer.
I would like to do a calibration process and connect trining apps.
The problem is:
In the application e-training I can see the trainer direto itself [ANT+]
but cannot see additional power meter and cadence sensors throuhg the ANT+ protocol!
[In the part devoted to "Advanced Configuration" e-training app]
I tried on Android mobile. The Trinerroad APP sees the trainer correctly, comprehensively all the sensors after the ANT protocol!
I would like to do calibration procees to make sure my power trinings are well measured by direto!
What is wrong?? Plese help.
Re: My E-Training don't see ANT+ power sensor from Direto
Postby Elite Admin S » Tue Dec 19, 2017 12:32 pm
If you want to use the Direto power sensor, you don't have to select any external power sensor.
That option is used only if you want to connect an external power sensor.
