With a Qubo Digital Smart B+ and an iPhone 6S there are only two Training Modes (Level and Program) available in the My e-training app. If I go into "Level" I can not adjust the resistance level at all. After downloading the app to my Mac it worked. Is there a limitation for the app on the iPhone? I don't have an ANT+ dongle, just using Bluetooth - from my Mac as well as the iPhone.
Can anyone suggest how to get level setting to work in the app as well?
Thomas
No Levels and Power mode in App with Qubo Digital Smart B+
thomas.friese
Re: No Levels and Power mode in App with Qubo Digital Smart B+
You should be able to adjust the resistance in level mode.
Please check again your configuration, as usually this kind of issue appears only if you select the wrong trainer
