Sensor Bridge heart rate doesn't work with Garmin Watch
ziggynlp
Postby ziggynlp » Fri Aug 01, 2025 1:21 am
I have an Elite Avanti trainer, and I'm trying to pair HR data from Garmin Epix Pro Gen 2 to the trainer using the Cardio Bridge function.
The watch is broadcasting HR data using ANT+, which is correctly picked up by other ANT+ devices as HR data, but when I try to pair it with my Avanti, it shows a message that no sensor is found:
While my cadence sensor paired successfully using the Sensor Bridge.
Any help would be appreciated.
