How to pair the Elite Square Buttons with Zwift?
ralf.proplesch
Postby ralf.proplesch » Sun Mar 02, 2025 10:15 pm
How do I connect the Buttons of the Elite Square with Zwift ?
lubos.olejar
Re: How to pair the Elite Square Buttons with Zwift?
Postby lubos.olejar » Tue Mar 04, 2025 8:09 pm
I believe not possible at the moment. Also I didnt find way how to change shifting mode. Default is Shimano mode. I am used to SRAM ... Then when you connect via app to square there is in app option to test buttons ... it doesnt work, after while I get error message that some buttons are not working. Software is half baked and and long road ahead.
lschaffer
Postby lschaffer » Wed Mar 05, 2025 9:46 pm
Yes these buttons do not have many functions in this current stage. But at least the virtual shifting is working well and I could replicate the gears of my bike. So now I use the square with the Zwift play controllers together
lucidam
Postby lucidam » Tue Apr 08, 2025 10:26 am
You can connect the buttons of the Elite Square with Zwift by pairing it through Zwift’s settings under the "Controllers" or "Steering" section — just make sure your device's Bluetooth is turned on and the Elite Square is in pairing mode!Monkey Mart Game
lunadam
Postby lunadam » Tue May 13, 2025 10:36 am
Speed Stars Have you encountered any specific issues, such as buttons not being detected or error messages in the Elite Square app?
lisamassa
Postby lisamassa » Tue May 20, 2025 5:31 am
To connect the Elite Square Buttons with Zwift, follow these steps:
Ensure Compatibility: Make sure your Elite Square Buttons are compatible with Zwift.
Bluetooth Connection: Turn on Bluetooth on your device and put the buttons in pairing mode.
Open Zwift: Launch the Zwift app and go to the pairing screen.
Select Devices: Look for the Elite Square Buttons in the list of available devices and select them to pair.
Test Functionality: Once connected, test the buttons to ensure they work properly with Zwift.
block breaker
