Hi!
I've been using the Elite Justo for 2 years now and for the first time in this winter it seems like its showing very low wattage and random rpm numbers - it also keeps losing connection to the ANT+ connector frequently.
I updated the firmware to the latest version and re-calibrated the device through the elite app.
Unfortunately the watts still seem way off to my power meters from 2 different bikes - difference up to 15% lower than what my bikes show me on average.
Is there anything I can do myself to fix this or is it broken and needs to be repaired?
thanks
Stefan
Elite Justo shows low watts
Re: Elite Justo shows low watts
Try checking for ANT+ interference, recalibrating multiple times, changing the power source, or resetting the device;Agario if the error persists, you may need to send it in for warranty.
