Dear,
I have my Turbo Muin Smart B+ with Misuro B+.
s/n of trainer: 52216
s/n of misuro: 29497
How many 'blinks' need to be at correct configuration of my device? 12?
If yes, please let me know, how can I reset the Misuro, because now I have 13 blinks of the light. Thank you for your help.
Thanks for your help.
reset of Misuro B+
Re: reset of Misuro B+
I confirm you have to set 12 flashes.
Press the button on the side of the battery, every time you press it, the flash counter increases by one (and return to 1 when the value has reached the max)
