New Firmware 201
bastian.buckel
New Firmware 201
Hi. Today I updated my Suito T with the Upgrado App to the firmware 201. Does anyone has found release notes to this firmware?
Re: New Firmware 201
I installed it yesterday thinking it would help to solve the issue I have "very hard resistance when increasing level, I have to stop few seconds and then the trainer gives a sustainable resistance that can increase up the desired level".
But now, myETraining cannot connect anymore and it's very hard for my other app (trainer day) to connect as well...
Thanks,
Alex.
Thanks,
Alex.
I updated last week.
Everything is working fine - but when I start or stop pedaling, it makes two strange electrical klicking sounds.
This does not sound very healthy ... but I did 3 sessions á 60 minutes and until now everything works as before.
But it would be interesting to know where the klicking sounds come from ...
I just updated mine last night. Seems to be fine but have not ride for another session yet...But struggling to understand why Elite can not provide any release notes (even just highlevel info) about the firmware...
alecoppola
I have issue controlling the smart trainer with Garmin devices after upgrade to version 201
alecoppola wrote:I have issue controlling the smart trainer with Garmin devices after upgrade to version 201
You're not alone. My Suito increases the resistance after 15 seconds.
I have the same problem too with my Garmin device.
The garmin sends the power number but Suito implements it for 5 seconds then revert back to a slope about 3.
Only way to change the resistance is now with Elite myEtrainer app.
Was working with firmware 198 before.
Hi there
I have the same issue with the Garmin devices (Edge and Forerunner) after Suito-T FW upgrade from 198 to 200.
So I've opened a case via e-mail and Andrea (from the "Elite srl" support team) provided me JSON file for quick fix, so this is really helps me with Garmin Workout execution. I've done quick 5 min test and it looks like quick fix works for me.
So try to register the ticket first and wait for the support team responce.
Regards,
Konsta
Regards,
Konsta
ladislav.marcincak
Same issue. While training with garmin edge resistance is increasing after pedaling for 10s without any reason. I wonder how it was tested before release in production. Mission failed successfully.
thomas.bandelier
this sh** bricked my suito during update - now I'm stuck in the "blue led" mode.
ANyone knwos how to recover ?
