So i had a ticking noise in my rampa. That has now resolved and it is quiet again.. however it connects and pairs with zwift as per normal. But when i ride on zwift i just stay on the side of the road whilst pedalling.
It displays my heart rate but there is no cadence or power data even though im pedalling? Any tips?
Blutooth pairing and connecting but no cadence or power
Shannocycle
Re: Blutooth pairing and connecting but no cadence or power
Please check to have set correctly the configuration.
If the problem persists contact Zwift customer care
kalman.peter79
Same problem with my trainer.
Did you manage to find the solution?
Thanks in advace
Peter
Thanks in advace
Peter
