Cannot connect to suito-t after failed firmware update
joost
Postby joost » Mon Oct 07, 2024 2:40 pm
Hi!
I tried to update my suito-t from version 191 tot version 197, but during the update (the radio update) the upgrado app crashed.
Now I cannot connect to the trainer anymore by bluetooth or ant+.
Does anyone have a solution? (like a factory reset or something?)
Regards,
Joost
appcrashes-ezgif.com-video-to-gif-converter (2).gif (150.52 KiB) Viewed 9289 times
vyktom
Re: Cannot connect to suito-t after failed firmware update
Postby vyktom » Fri Oct 03, 2025 2:06 pm
i ran exactly int othe same problem. any solutions? thx
marcusthome
Postby marcusthome » Thu Oct 09, 2025 3:24 am
I had the same problem today.
Did you guys find any solution?
michiel.brands
Postby michiel.brands » Sat Dec 13, 2025 8:02 pm
Here aswell same problem. Not a single way I contact the trainer anymore and also lights dont blink anymore (not even power), even tho there is power on the trainer as u also hear the trainer adjust once u put power on (after putting it off for a few minutes first)
Return to “Suito”
