Direto power smoothing
Westmatix
Postby Westmatix » Mon Nov 20, 2017 9:01 pm
Tried adjusting power smoothing from default to 6 and whilst it made power more smooth it has made 200w more like 300w . Has anyone else had this or found a way to have a smoother power reading?
wimbos77
Re: Direto power smoothing
Postby wimbos77 » Tue Nov 13, 2018 10:05 pm
I am struggeling as well with the power smoothing.... have you find out which setting is the correct one?
Will it also affect the performance on Zwift? 8% on myetraining feels more heavy when riding 8% on Zwift....
looking forward for your experince
kind regards,
Wim
haigh.ian
Postby haigh.ian » Wed Nov 28, 2018 8:04 am
On zwift do you have the difficulty setting at 50% (default) or 100%.... Basically Zwift defaults to 50%, therefore an 8% climb is 4% (at 50%), and the same for downhills. Note that you still need the same power to go up at the same speed, it just feels like a lesser gradient. They have reasons whey they use 50%, I've left it there. But you can go in a change it yourself if you want the inclines and downhills to feel more realistic.
I am keen to hear what smoothing setting people are using on the Direto.
