Should Myrealvideo automatically adjust your interactive trainer
Turn your outdoor training into My RealVideo!
keithkemble157
Postby keithkemble157 » Sun Mar 10, 2024 6:46 pm
HI Folks,
It is my understanding that when you play a Myrealvideo via MyEtrainer it should automatically change the setting within your trainer (assumes interactive trainer etc). This is based upon the terrain / slope etc
Please tell me I am right or wrong.
I believe this is called simulation mode
Cheers
basicpermit
Re: Should Myrealvideo automatically adjust your interactive trainer
Postby basicpermit » Thu Aug 08, 2024 4:40 am
keithkemble157 wrote:HI Folks,
It is my understanding that when you play a Myrealvideo via MyEtrainer it should automatically change the setting within your trainer (assumes interactive trainer etchappy wheels). This is based upon the terrain / slope etc
Cheers
Recording from a car is not a problem, but you should try to keep an appropriate speed.
You should drive with a speed as close as possible to the speed you'd have by bike.
I know that this is almost impossible of course, but try to go slow if you can. Otherwise, the video will be less fluid when you'll reproduce it on your trainer.
Return to “myRealVideo”
Users browsing this forum: No registered users and 84 guests
