Using qubo smart digital b+ in the cold
supaphonic
Postby supaphonic » Sun Nov 19, 2017 9:09 pm
I've set my trainer up in an unheated room outside. My power supply is from a 100ah battery and power inverter, so running off grid. I can use power tools like drills so there is no shortage of power, but my trainer will not give me any resistance.
Does the cold affect the elastogel so it will not add resistance? I've used the trainer in my house and it seemed fine, so I can only think it is the cold.
Any suggestions?
Re: Using qubo smart digital b+ in the cold
Postby Elite Admin S » Thu Nov 23, 2017 12:56 pm
Is it possible that you're not providing enough amperes to the trainer with your power supply.
The cold doesn't influence the behavior (unless you are way under 0°)
