Dear all,
In your opinion is possible to use the smart trainer (I have Suito) without power cable and so electric current?.
Any trobule?
I would like to use the trainer for 5-6 minutes for war-up e.g. before functional WOD (home gym).
Thank you for feedback
To use without power
ymarti.ymarti
GOD SAVE THE RIDER
Re: To use without power
You can use it, there are no problems. Simply you won't have the control of the resistance or any data
ymarti.ymarti
Using a smart exercise machine like Suito without a power cord and current is completely possible, as long as you use it for a short time like 5- Block Blast 6 minutes to warm up. However, make sure that you do not encounter any battery or performance issues when using it for a long time. If you feel that the machine is running unstable, it is best to check again or fully charge the battery before using it.
