I have an issue with my Elite Justo.
When I open power based training on my Garmin Edge 530 or Garmin Fenix 7. Power is being applied to my trainer but only for 5s. After 5s it returns to default value (100W).
Could you help with it? I had this issue last year and I was in contact with Garmin but unfortunatelly no luck.
No issues when using zwift of other app when connected via bluetooth.
ERG mode do not work with Garmin
Re: ERG mode do not work with Garmin
Any updates on that? Looks like, I'm having exact same issues on a Edge 1040 and Forerunner 255 devices.
I've just opened a support ticket on support.elite-it.com.
I've just got the reply from the support.
Solution is quite simple - after disabling the `Stand alone/plugged in trainer` option via MyETraining app, the trainer works well with structured workout via FE-C both on garmin edge 1040 and on forerunner 255.
https://elitesrl.zendesk.com/hc/en-us/a ... rce=search
